6 members (TooMany2count, 78buckshot, Gdads51, KEVINSKI, dt235sd, 1 invisible), 161 guests, and 1 robot.
Topics128,081
Posts1,056,069
Members48,434
Apprentice
Apprentice
1 Offline
Quick question here. Are the radiator supports the same on Big Bolts and my 1951 3100?
I really need one and I saw this on Ebay "52 Chevrolet 2 ton truck radiator support" http://cgi.ebay.com/ebaymotors/ws/e...item=220037530512&fromMakeTrack=true
Your help would save me time and money, Thanks
I think not, but some checking in the parts book would tell you.
I'll try to in the morning if someone does not beat me to it.
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg, that’s exactly what I was asking about on another thread, i.e., a parts book. Where do I find a parts book, are they reprinted, or are some on line?? I’ve got a 1950 3600 and am interested in interchangeability. .
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Maybe a Master Parts Catalog is what you are looking for?
These show up on eBay every so often (that's how I got mine) and they are available on CD-ROM on eBay (and maybe from some of the repo parts dealers).
The price is right for the on-line one above.
There are also Interchangeable Parts Catalogs that show up on eBay (I got s 1929-1954 IPC for 1929-1954 Chevrolet cars and trucks on eay several years ago).
That's the link.
I have an original catalog too.
The support on ebay looks to expensive for the weld repairs done to it, about $20 delivered is all I would pay for it, and I happen to be looking for one exactly like it.
---All pictures---
I
I Offline
The one picture in the ebay link, will fit any of the big bolts. It was common practice to cut the top bar out when removing engines, instead of trying to lift it up over the front clip. Most times you find them missing the top bars center part. Hard to find one thats not been cut there or at the top of the U.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
Another reason that many radiator frames have the top bar disconnected from the radiator frame is so the fame could be mounted backwards and the radiator mounted on the inside would then not touch the long-shaft water pumps on 55-62 235/261 engines (for a quick and easy engine replacement). The top bar from the radiator frame was still needed so that the radiator shroud (and hood latch) had a cross brace, connected to the fenders/etc.
Apprentice
Apprentice
1 Offline
Got a support last weekend that is just about 2in too tall. Can I just cut and weld this?
Has anyone done this?
I don't see why you can't cut and weld it. I cut the top bar off my 2-ton frame to change engine after I noticed it had already been cut and welded twice. Now it has 3 welds per side.
I
I Offline
I would say, no you just cut it off. Theres a ton of stuff that bolts to this piece. You need to check out if all the other parts line up in the holes. You have fender braces, inner fenders, lower rad baffle, upper rad baffle, and the rad itself. May be a case you were you would need to cut it in the middle, bottom end, or top. Also on my 47, you could just turn the support around back words, as the lower baffles bolts are at an angle, and this would put them where you'd have to drill new ones. I wonder this one being taller is from a COE. I've also found some with the wrong mount on the bottom making them taller.
Jeff
1953 3/4-ton
