4 members (greenie-reddy, pauld, 2 invisible),
85
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21747 04/28/2004 2:08 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Subject is '61 Apache 10. The goal to is to have a Sanden A/C compressor to operate the Cool Pak underdash unit, keep the alternator conversion already done, and add a power steering pump, in conjunction with a REZ kit conversion. I have Vintage Air bracket to mount alt, and compressor on the driver side of engine. The P/S pump needs to go on that side as well. The ideal thought is to find a way to mount the compressor on the passenger side of engine. Anybody have any experience with this? Ideas for fabing a bracket for the compressor onto the pass side?, or fitting the P/S pump onto the driver side with the alt and compressor? Thanks, Tony | | |
#21748 04/28/2004 9:17 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | :confused: What engine are we talking about here? 235?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#21749 04/28/2004 10:58 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | | | |
#21750 04/29/2004 2:04 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I run my alternator on the passenger side of my 261. I use a little NASCAR alternator and it fits very nicely. To do it, I had to go to a double harmonic balancer pulley and a double water pump pulley. I have seen a power steering unit mounted below the A/C compressor, but the mount would most likely have to be made. It ends up inside the frame rail. The A/C was in the generator position and the alternator above it. Some one might offer a mount for the power steering in that position, but I'm not sure. The guy that has the one I know of had it made. He uses a double balancer pulley to run the power steering. The rest of the set up is done the way you usually see it done. On your truck, there is probably enough room to do that.
#21751 04/29/2004 7:32 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Hey 6, where did you find your 2 sheave balancer? I may add AC or PS to my truck and I want to do it that way. A double pulley is not really necessary on the water pump if you use a shorty belt.
#21752 04/29/2004 11:33 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | A 2 groove pulley damper was used on late 50's cars with a 235 and AC and power steering or something like that.A damper from a 230-292 engine as well as the small block V-8 works on a 235/261 from what guys tell me.Not that these balancers may have the correct dampening for the older 6's and the damper snout may need a reduction in length.And there's limited room like the man says. | | |
#21753 04/29/2004 3:31 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | The truck has a two groove damper already, maybe I lucked out there. The vintage air backet is set up to utilise a two groove compressor with the front groove running off of the rear groove on the damper, the rear groove on the compressor to run a short belt to the alternator above it. So the front groove on damper can run P/S pump. Any clues where I might find a pic of the car setup with P/S? Thanks to all for your help so far, it's starting to make sense. | | |
#21754 04/29/2004 6:02 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | 4onthe Floor; I was lucky on the two groove harmonic balancer. Went to the wrecking yard about six months ago and walked right up to a 57 Chevy car with the front sheet metal pulled off of it and there it was. Pulled it off in about one minute. Some things are meant to be. It has a small wear groove where it goes into the timing cover seal. Should be OK. I think somebody makes a kit to repair the groove caused by the seal. Yachtcare; I would say you are lucky to have one. They are not too easy to find. I've been looking for a second (better) one and have not found one. I have no idea as to where to send you on a power steering setup picture. Maybe some of the 55-56-57 guys know. Also, check some of the repo guys that do repops for 57-62 trucks. Two other places to ask questions are Jim Carter and Obsolete Chevrolet in Nashville, GA. Good luck!
#21755 04/29/2004 6:16 PM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | Use a repair sleeve for the SBC. It works fine and is cheaper than the sleeve called-out in the parts book.
Jason
