0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#217402 10/10/2006 3:53 AM
I dont know where else to ask this ?
I have to replace the cables on my parking brake but the cross member of the frame has been moved forward a few inches to support the transmission for some reason. The brake parts that are bolted to the frame and holds the lever are too near the trans to be put back the way it was.
Is there a custom parking brake set-up that can be used?
#217403 10/10/2006 4:31 AM
Tab Offline
It's just the parking brake? Get a 1 foot section of a 4x4 and throw it under the wheel when you park. Problem solved! grin
You haven't been a Stovebolter for very long have you? wink
delete my account and pictures
#217404 10/10/2006 2:48 PM
darn! Why didnt I think of that. Duh!
#217405 10/12/2006 3:35 PM
Quote
But it didnt pass the inspection test--I need two 4x4 on strings -- gettin complicated... http://www.stovebolt.com/bboard/ubb//icons/icon7.gif
Icon 7
#217406 10/12/2006 3:54 PM
Easiest thing to do is update to a 66-up setup, doesn't use an idler or crossmember setup, just cables. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#217407 10/16/2006 12:55 AM
Thanks Brian,
I already have the new rear cables. I think I can set it up. Where could I see a sketch or picture of the 66 cables etc? that would help decide what's the best way to go. Jim
#217408 10/16/2006 1:04 AM
why wont those darn graemlins work for me?
#217409 10/16/2006 1:28 AM
I started to suggest geeting cables for a 3/4 ton but then I saw you already have new cables. The other thing you might be able to do is to extend their length with some threaded rod.
#217410 10/19/2006 3:44 AM
Thanks for the info.
I have it set up temporarly--if it works well it can stay if not its back to -- scratch head pace up and down take a break till the bulb goes on.
