1 members (UtahYork), 76 guests, and 1 robot.
Topics128,049
Posts1,055,740
#217350 10/09/2006 3:14 PM
Apprentice
Apprentice
I heard that rhe john deer cornhead lube would harden after application. Izzat so? ----- Will synthetic brake fluid work and blend in with regular brake fluid? THANKS
rrf
#217351 10/09/2006 4:06 PM
3B Offline
Hy 50 chevy 3100, I don't know about the lube, but the brake fluid types should definately NOT be mixed, the different types have very different properties, hope that helps.
#217352 10/09/2006 4:09 PM
50 chevy 3100,
I can't answer your cornhead question, but I am pretty sure DOT 3 and DOT 4 brake fluids are compatible when mixed together, and those same fluids, if synthetic, will also mix with all regular brake fluid.
What you don't want is a DOT 5, which is a silicone product. It is not compatible with other fluids, and only recommended for a system designed for DOT 5 brake fluid.
Stuart
