0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 27 Apprentice | | Apprentice Joined: Apr 2003 Posts: 27 | I heard that rhe john deer cornhead lube would harden after application. Izzat so? ----- Will synthetic brake fluid work and blend in with regular brake fluid? THANKS
rrf
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 50 chevy 3100, I don't know about the lube, but the brake fluid types should definately NOT be mixed, the different types have very different properties, hope that helps. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 50 chevy 3100,
I can't answer your cornhead question, but I am pretty sure DOT 3 and DOT 4 brake fluids are compatible when mixed together, and those same fluids, if synthetic, will also mix with all regular brake fluid.
What you don't want is a DOT 5, which is a silicone product. It is not compatible with other fluids, and only recommended for a system designed for DOT 5 brake fluid.
Stuart | | |
