| | | Forums66 Topics128,282 Posts1,058,492 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21712 11/19/2002 4:04 AM | Joined: Nov 2002 Posts: 4 Junior Member | | Junior Member Joined: Nov 2002 Posts: 4 | '54 Corvette, Blue Flame Six. Just rebuilt, stock.
Engine builder said to drive it a little and bring it back for a final valve adjustment. Been a little cold, so the first drive was only about 20 miles. Saturday I take it out, everything seems good so I go out on the interstate. About 12 miles into this adventure, I notice oil pressure isn't as high as usual, its just above 30psi at 3000RPM. Keep an eye on oil pressure. It slowly drops over the next few miles. By the time I get off six miles later (having slowed down and prayed pressure wouldn't go away altogether before the next exit), pressure is below 15psi. Get off, drive over the overpass, shut off engine and coast into the gas station. By the time I shut down, pressure is barely showing on the gauge, though it does drop on shutdown. Nice rattle too. Coast into gas station. In the last 10 feet of the coast, coolant starts blowing out the overflow line. Maybe a quart or so blows out. Temp gauge never climbed above 190 or so, but it is a Bourden (sp?) tube type, accuracy unknown. Smoke coming from the vents on the valve cover.
Checked oil before leaving home. Checked oil after disaster. Clean and full both times. No coolant in the oil, still looks new.
Now the thing is sitting in the garage, and still smells really bad two days later. Burned oil smell?
What went wrong?
Did the oil pump fail? If so, do they die slowly over several minutes like that? | | |
#21713 11/19/2002 4:34 AM | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | The overheating can affect oil pressure, but I doubt that much. A rattle with low oil pressure usually means that there is a bearing gone. Once the bearing has lots of clearance, the oil pressure drops because it is pouring out of the bearing. I would say to you that the rebuilder will probably have a responsibility here. I would get some advice on how to approach it in order to get the best outcome. | | |
#21714 11/19/2002 5:26 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It sounds to me like something was left loose. Hopefully not much damage was done. How come you haven't called the rebuilder yet in those two days?
54 3100 with 235 62 flatbed dump C60 with 261
#21715 11/19/2002 5:38 AM | Joined: Nov 2002 Posts: 4 Junior Member | | Junior Member Joined: Nov 2002 Posts: 4 | Incident happened Saturday afternoon, he was closed and unavailable. I talked to him this morning, first time he was open since the incident. He is a good guy I've dealt with a long time, and I know he'll make it right. Since I don't drive the car for transportation, he wants to wait and get it back in the shop next week so he can get some other stuff finished he is working on now. I didn't make a fuss about that because he always gives me a good deal and stands behind his work. | | |
#21716 11/19/2002 8:37 AM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit guy! sorry about your misfortune...hope all goes well. off-topic, but have you considered installing a coolant recovery system? i know it's not OEM, but your FLAPS has a generic one, selling for under $20(including radiator cap). it did wonders for my coolant"puking" problem.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#21717 11/19/2002 4:20 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Oh, crap. Im so sorry to hear about this!
If the '54 vette engine is like the one in my '54 Bel-Air, the main bearing clearance is set with shimstock between block and caps. If the clearance isnt set right with these shims, the bearings will be too loose or too tight.
What was your oil pressure before this happened? What weight oil are you running?
My bet is bearing failure. If the oil pump was new, and the lines installed right, Im sure it is OK. It is very unusual for a cam bearing to spin or fail, if it was installed properly. A rod would have started to knock like crazy if a rod insert was the culprit.
I'm going to bet that either your #2 or #3 main bearing insert has failed due to improper installation. Drain the oil into a clean pan for inspection. Bearing failure will show up as chips, chunks and ribbons of metal in the drained oil.
Please let us know what happened!!
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#21718 11/20/2002 4:37 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | 54_blue_flame.
Believe it or not, the exact same question was posted on the Inliners message board - word for word. By a user with the exact same user id. Go figure! :confused: | | |
#21719 11/20/2002 6:01 PM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 | [QUOTE]Originally posted by ftyler: 54_blue_flame.
Believe it or not, the [b]exact same question was posted on the Inliners message board - word for word. By a user with the exact same user id. Go figure! :confused: [/b][/QUOTE  howziit guys! yup...and at chevytalk.com also. Hmmmmm, imagine the odds of the exact/same situation! J/K.
Myron
#21720 11/20/2002 6:16 PM | | Anonymous Unregistered | | Anonymous Unregistered | Always good to get more than one opinion . . . I have asked questions on the Inliners site and here - gotten good info from both sites. | | |
#21721 11/20/2002 7:28 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | No matter who you ask, the same Richard Pryor joke applies:
The motor said F*&@ it and fell out.
chip
#21722 11/21/2002 5:17 AM | Joined: Nov 2002 Posts: 4 Junior Member | | Junior Member Joined: Nov 2002 Posts: 4 | Yup, I sure did post the same question multiple spots. Y'all missed the NCRS Technical Discussion Board.
I've gotten some good responses on all. The NCRS Board did come up with something no one else did. A gentleman there told me that there is a 3" freeze plug on the front of a 235 block that should be left out for a Corvette due to the unique water pump (made for the low hood). I know the water pump is unique, 'cause they are $600!
Will let you (and the other groups) know what is found when the pan drops next week. Thanks for the responses. | | |
#21723 11/21/2002 3:23 PM | Joined: Dec 2000 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2000 Posts: 54 | Blue Flame, I see you're in FtC, What shop are you working with? | | |
#21724 11/21/2002 4:44 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | That may address the cooling issue, but the massive loss of oil pressure should not be an effect of pure overheating. Oil pressure won't be that affected by engine temperature unless the engine is REALLY hot to the point of cracking or heat-seizing. This should be especially true in a new (healthy) engine.
Actually, I had two main bearings seize in my '54 sedan engine, due to incorrect adjustment. The engine lost oil pressure and also overheated, due to the bearing failure.
let us know!
chip
#21725 11/22/2002 3:19 AM | Joined: Nov 2002 Posts: 4 Junior Member | | Junior Member Joined: Nov 2002 Posts: 4 | I go to Bowers Racing Engines.
Definitely agree that the oil pressure drop was not caused by the overheating. We'll see what shows up when the pan comes off. | | |
