3 members (Woodcmiami, Cosmo, 1 invisible),
75
Mod | | | Forums66 Topics128,150 Posts1,056,991 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 67 'Bolter | | 'Bolter Joined: May 2004 Posts: 67 | I think it is the same but I will ask the people that knpw. On 55-59 Chevy and GMC 1/2 ton trucks, are all the fenders, hoods and cabs (I know the dashes are different)the same as far as bolt holes lining up and so on? Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mule 1951, model for model, yes, hope that helps. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Yes, that is correct. 55-57 Chevy and GMC truck sheetmetal will swap around on 55-57 cabs. 58-59 have different locations for the hood hinges and narrower hoods to accomodate the wider fenders otherwise they swap around. Some GMC's have different radiator and core supports. | | |
