| | | Forums66 Topics128,057 Posts1,055,816 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | how do you repair this bad boy? When I switch mine on, it stays stationary.. Once I get the blades moving, they go really slow, barely movin... I shut them off they snap right into the off position...
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Do a search on the Hemmings Motor News site for wiper motor repair. There are several rebuild shops that advertise regularly in Hemmings.
| | | | | Joined: Aug 2006 Posts: 65 Member | | Member Joined: Aug 2006 Posts: 65 | Mike, it sounds like you're not getting enough vaccuum. first thing that i would do would be to check the line for cracks or obstructions inside the line. Also check to make sure that your grommets are in good shape so that the transmission arm isn't in a bind. | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | I just put a brand new vacuum line on the motor... no creacks or obstructions when I drive I hear a psst... ever 30 seconds or so...
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2006 Posts: 21 New Guy | | New Guy Joined: Apr 2006 Posts: 21 | I believe the gaskets in your motor are made of leather. Use oil for leather like the kind you might use on a baseball glove. Remove your motor and put a few drops of oil in the vacuum holes, then work it back and forth. Unfortunately, these old vacuum motors never worked that well. Every time you climb a hill (or otherwise step on the gas) they'll come to a stop, let off the gas, and they go again! I replaced mine with electric. Dave
From the web ... The Best Glove Oil?
For nearly 100 years, baseball players have been oiling their gloves. The oil of choice was neatsfoot for many decades. Neatsfoot used to be the oil that came from boiling the leg bones of cows. Now it’s any old cow oil with additional ingredients to make it clear and light.
Neatsfoot was so popular, even librarians used it on leather-bound books. But they were in for a horrible surprise. After a few years alone on the shelf, that leather started to petrify and crumble. Now librarians use lanolin – a lighter oil derived from sheepskin. You should too.
You can get lanolin in Lexol products, right at your hardware store. Lanolin lubricates the leather like neatsfoot, but it doesn’t make it darker and it doesn’t make it heavy or harm it over the long term.
If you still prefer neatsfoot oil, which gives gloves a nice tacky feel, go easy with it. Or try Lexol nf, their neatsfoot/lanolin mixture.
Are you partial to petroleum jelly? Some glovers swear by it, others say it clogs the pores and collects dirt. Just remember: you oil a glove to help lubricate the leather fibers after a long season has robbed some of the oil that was put in at the tannery. You don’t use oil because a glove is “dry” – since leather absorbs all the moisture it needs from the air. Go easy on the oil, and don’t depend on it to break in a glove either. That takes good old-fashioned elbow grease. | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | I'll check it out... I am trying to keep the vacuum motor, in colorado it does not rain that much, and I think it would be cooler with it...
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | oh yeah, I put rain x on the windshield as well... the combo should work out ok
