2 members (Brian Moore, panel fan), 166 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#21639 05/27/2003 8:26 PM
Some news:
In my quest for 7/8" wheel cyls for the front of my '55.1 truck, it was looking like I would have to have my old ones sleeved; no listing anywhere for new aftermarket cyls - not even in Wagner!
In looking through the brake books at my local jobber, I kept noticing the same shoe listing for 1.5 ton and bigger trucks up through the '80s: a # 109 shoe for 14" front brakes, which is the same shoe that my truck uses....
I took a chance and ordered front wheel cyls for 1964--'8? trucks (40, 4000 series) with 14" drum brakes, and was pleasnatly surprised when they arrived and were identical to my originals (fit '55.1 to '59) except that the flex hose screws into the cylinder @ a 45 deg. angle from the rear, instead of at a right angle to the wheel cyl bore as original.
There are no clearance problems with the steering knuckle, and no hard bends or "stretches" put on the flex hose. I might adjust the position of the flex hose bracket slightly to improve that geometry, but otherwise, it's a bolt-on deal !
grin
(Not trying to divert business from our friends in the sleeving field - I am going to have my master cylinder sleeved - but for those of us on a tight budget, this is an economically attractive possibility for a discontinued part !)
Sadly, though, those #109 brake shoes are between $60 & $80 for the axle; can't wait to get into the rear wheels ! :o
Bigger truck, bigger repair bills ! :rolleyes:
I still like it, though !
Frank McMullen
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
#21640 05/27/2003 11:17 PM
Have you thought of having your shoes relined? There are people around in that business and it is usually fairly resonable.
1951 1 Ton Completed
#21641 05/28/2003 3:22 PM
Would love to have my old shoes relined - for both cars & trucks; just haven't found anybody in my area that still does it.
If anybody out there has leads for jobbers who re-line brake shoes in the NE Pennsylvania region, please give us a shout!
Thanks!
Frank McMullen
Frank McMullen
#21642 05/28/2003 4:10 PM
Yes getting them relined can be really cheep, I did a set 2years ago for $20cdn for 12*2 1/2 here in Toronto. I also found that sleeving can get quite expensive $60 vrs $32cdn for new (not nos) and the master cost me $50us newand $120 to be sleeved..
