| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | is it possible to remove the 3 speed colum shift tranny in my 51, 3100, without removing the motor?, if so how?,,thanks,, ron | | | | | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Just undo the torque tube bell from the transmission and slide it back. Then you can unbolt the u'joint and seperate it from the transmission. Support the torque tube with a jack while doing this. Raise the tube enough to clear the trans. Remove the four bolts holding the transmission, (two inside the clutch housing) and pull it out. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | thank you verry much,,, ron | | |
