5 members (Donf, TUTS 59, Gdads51, massey1951, JW51), 90 guests, and 2 robots.
Topics128,038
Posts1,055,583
#216245 09/23/2006 1:49 PM
is it possible to remove the 3 speed colum shift tranny in my 51, 3100, without removing the motor?, if so how?,,thanks,, ron
#216246 09/23/2006 3:42 PM
Just undo the torque tube bell from the transmission and slide it back. Then you can unbolt the u'joint and seperate it from the transmission. Support the torque tube with a jack while doing this. Raise the tube enough to clear the trans. Remove the four bolts holding the transmission, (two inside the clutch housing) and pull it out.
#216247 09/23/2006 6:46 PM
thank you verry much,,, ron
