| | | Forums66 Topics128,137 Posts1,056,437 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I'm exploring all possibilities on putting an ifs under my '50. I've seen some who bolt in the suspension from a 67-84 pickup to their frames. My question is will the rotors from lets say an s-10 or some other vehicle with a 5 x 4.75 fit on full size spindles? I'm trying to keep the same bolt pattern as I have a camaro 10 bolt rear.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | With patientsand money you can make anything work.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Those rotors won't interchange, the bearing sizes are too small for that spindle. Have you considered a Heidt's or Fatman's front suspension? You can specify the bolt pattern on the brakes on those.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | do like im doing,get a dual pattern wheel for the spare.
64 c10 89 rs 62 econoline 50 ford coupe
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | ummm.....They don't make dual pattern wheels that have 5 and 6 lug, only ones that have 2 or 3 different sizes of either 4 or 5 lug.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I found a machine shop that will drill the smaller bolt pattern. I have all the of the mustang parts except the crossmember. I do have the stock member but can't find anyone willing to weld it in for me. (too much fabricating) I thought about the aftermarket crossmember but I also have access to a free suspension from a full size truck. I can put it in for 1/3 of the cost of buying the mustang X member and the labour to put it in.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Re drilling the full size truck rotors might be the best option, they have larger brakes than the s-10 or mustang 2. There are also some GM spare rims that are made with 2 bolt patterns, 5x5 and 5x4 3/4. They were used mostly on Cadillac and Oldsmobile.
Bill Burmeister | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have a set of mag wheels that are both 5 x 4-3/4 and 5 x 5. Those wheels would fit both the pickup IFS and the Camaro rear.
Today they are on a '78 Monte Carlo and years ago I ran them on a '75 Chevy pickup.
No, they aren't for sale, but I'm sure there are other sets like them out there.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I already have a set of 16 x 7 tork thrust II's in the 5 x 4 3/4 pattern with 4" back spacing. I've seen some trucks done with this set up and some of them have the wheels sticking out from the wheel wells. I'm hoping to avoid this removing about an 1 1/2 inches from the center of the X member.
