2 members (elhippie64, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | i just brought home my 235 motor out of a 48 cab over my question can i use the bell housing and clutch with my 3 speed collum shift tranny in my 51 half ton if not will my 216 bell housing fit the coe, also i have the tranny out of the coe if anyone needs it,,, ron | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I don't see any reason you couldn't use that combination. As I understand it,the bellhousing will interchange and I don't think you'll have any trouble as long as you keep the flywheel,clutch size and bellhousing matched to each other. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | thank you for the info,,, ron | | |
