0 members (),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I'd like to experiment with using soda to clean carbs and delicate aluminum parts. Can anyone share their experience with using soda and advise where to buy the stuff in bulk. Thanks!
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | They do a lot of soda blasting here at the depot I work at. It doesn't chew up the metal as bad as grit or glass bead. Should be able to get it in good sized bags at a pool supply place although you may be able to find it cheaper someplace else. I have seen it in 3 or 5 lb. boxes at Sams.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Thanks Bruce, that is the type of tip I was hoping for. I would never have thought about investigating a pool supply vendor.
