| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I have a 49 Suburban and am in the process of rebuilding the doors. I have new glass felt, etc but have just discovered the regulators are worn out and need to be trashed. I am looking at It's a Snap Wire and Cable in the Classic Truck magazine and they are almost as cheap as new rollups from other vendors ( $145). I'm looking at their competition they seem to be the price leader and use GM motors. Has anyone used them and can give me a reference? Any other vendors you like in the same price range?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | For AD doors the power window units that have the motor mounted to the vertical channel pose clearance problems inside the door. The units with the motor attached to the vertical channel via a cable seem to fit better and work fine. | | | | | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | I've used them in all kinds of rods and in trucksand they work great for me and mount easly too.I also use their wiring kit and the gauges too. Good luck.  | | |
