2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#215797 09/14/2006 7:29 PM
I'm in the process of rebuilding the front end in my 55.2 3/4 ton GMC and got a surprise when I pulled the drag link off.
Early 55.2 Drag Link
Found some notes in the '59 Chevy master parts book on the drag link part number about a "double taper fitment" and "requires replacement of Pitman arm and steering arm".
GM appears to have had a better idea that didn't last to long.
I've got replacement parts located (Tom Myers in Miami,OK) but was curious if anyone else has seen this setup.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#215798 09/14/2006 10:28 PM
hmmm.. it might be a bit out of tolerance?
keep us posted on your status.
Another quality post.
Real Trucks Rattle
#215799 09/16/2006 2:15 AM
That pitman arm looks just like mine. I didn't have that tapered nut, though, as the original drag link was missing from the truck. I have an aftermarket drag link on the original pitman are, haven't had any problems, I just installed the new drag link with a flat washer to keep the nut out of the taper.
Bill Burmeister
