| | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I'm in the process of rebuilding the front end in my 55.2 3/4 ton GMC and got a surprise when I pulled the drag link off. Early 55.2 Drag Link Found some notes in the '59 Chevy master parts book on the drag link part number about a "double taper fitment" and "requires replacement of Pitman arm and steering arm". GM appears to have had a better idea that didn't last to long. I've got replacement parts located (Tom Myers in Miami,OK) but was curious if anyone else has seen this setup.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | hmmm.. it might be a bit out of tolerance?
keep us posted on your status.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That pitman arm looks just like mine. I didn't have that tapered nut, though, as the original drag link was missing from the truck. I have an aftermarket drag link on the original pitman are, haven't had any problems, I just installed the new drag link with a flat washer to keep the nut out of the taper.
Bill Burmeister | | |
