1 members (walterhvogel),
87
Mod | | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I know this horse has been beaten to death, but since I have my steering box apart, I'd like to get everything together correctly. I've been trying to find the Penrite Steering Box lube but all of the suppliers I've found on line are out of stock and don't know when they will be getting more. Classic Auto Lube is closing down and has no more.
Anyone have a source? or a relative in the U.K or Australia that can send us some? | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I've heard John Deere Cornhead lube is an alternate to Penrite that is readily available at your local tractor supply- Check your yellow-pages.
| | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Todd if you want to use the Penrite lube send me a pm and I'll track some down for you.
Cheers mate
Bob | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see ..............
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=000596#000002
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=001130#000001
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=005259#000002
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003904#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004194#000007
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks all for the replies. I received a return email from the supplier in the UK. FYI they are working out details on a distributorship with a company in Escondido CA (Restoration Supply Company) and the representative will let me know when they anticipate having product.
In the interim, hopefully mozzie can locate some for me. | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Originally posted by NM51: I've heard John Deere Cornhead lube is an alternate to Penrite that is readily available at your local tractor supply- Check your yellow-pages. That depends on where you are located in this big big country.  None of the John Deere sales and service centers in Northern California have even heard of it, not even in the farming country over here on the left coast. It is listed on the John Deere website, but they don't retail it. Believe me, I've looked for it locally and called around to places that i knew I would be passing through while travelling.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | I used John Deere Corn head grease with good results, it is a "self leveling grease", I have no leaks, I previously used SNAPPER gear oil, and before that 90W gear oil (what a mess that was). The grease is green in color, how appropriate since it comes from John Deere 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
