1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21544 08/13/2003 10:11 PM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | Hey guy's , I need a little help with the bottom end on my truck, first of all , I have been told that my bearings should plasti gauge to " .0015 to .003 ". Is this correct? Second , does any one know off hand what to torque my mains, and jurnals to. If you did'nt notice , I have had little MAYDAY, with my 41 pu., Since I have the 235 half disassembled , and it seems that I don't have the oil presure that I once did , I would check the mains. If you think I should look for anything else while working on it please mention. Thanks Don
Don
#21545 08/13/2003 11:30 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | The cam bearings and the main bearings have the greatest impact on oil pressure, in that order. If the engine is torn down to the block, go ahead and change the cam bearings. Cam bearings, correctly sized mains and a new oil pump will bring the pressure back to between 30-45 PSI where it should be. Don't forget the rod bearings while your at it. Its best to have the crank turned .010" undersize and new bearings fitted since you're in there.
The .0015"-.003" is correct clearance for main and rod bearings on 55-62 235 engines. .002" is optimal. Check your manual, but I think main bearings are torqued to 90-95 ft-lbs, rods are 40-45 ft-lbs or so. Somebody else will clarify Im sure.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#21546 08/14/2003 4:36 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | Thanks for the info , I did'nt know the cam bearings had that much impact on oil presure. I will take it as it comes from here . Thanks chiphead.
Don
#21547 08/14/2003 5:46 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Don, the torque on the mains should be a bit tighter- go to 100-110 ft/lbs on the mains. The rods are 35-45 ft/lbs. Is this a 216 or 235? what year? The reason I ask isn't that there is a difference on what I have told you, it's just that since you are this far in there are other things that you can do to improve your engine, just depends on what you have for what you can/want to do.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
