1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 36 New Guy | | New Guy Joined: Dec 2005 Posts: 36 | Just replaced door gaskets on my 1953 chevy 3100. Changed them because only parts of them were there and old. Doors were loose and maybe not lined up to begin with. I took the doors off to clean them up. Need some info help in getting them lined up again. They are installed right. How much and which way is the adjustments? What should I look for? Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | blkhrn, I have enclosed a link that might help. There is also a little blurb in the Tech Tips section on adjusting the doors. http://www.chuckthetruck.com/page20.html Stuart | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Always, Always mark the bolt locations before removing them! That way you have a reference when reinstalling them and don't have to ask this question. I'm not putting you down because you are far from being the first to make this mistake. That also applies to the hood, decklid and anything else you remove with the intent to reinstall.
| | | | | Joined: Dec 2005 Posts: 36 New Guy | | New Guy Joined: Dec 2005 Posts: 36 | That's the first thing I did before I removed each door. The doors were re-attached according to the markings. The doors line up the same way before the removal. They just won't close all the way. | | |
