5 members (37 GC, ShopRag, klhansen, Hotrod Lincoln, 1 invisible), 178 guests, and 2 robots.
Topics128,147
Posts1,056,797
Members48,454
#215230 09/07/2006 2:31 AM
Junior Member
Junior Member
I was wondering if anyone else has seen this: I went to Painless wiring to find a harness for my 50 Chevy Panel. Called the toll free #, got the item number and went online to their site to see the price. Painlesswiring was in the URL but when I clicked on the item and the add to cart, the URL became Shopatron.com. I searched for such an animal, and it supposedly doles out orders to various painless dealers and lots of other products for other companies. No problem except that the company it directed me to was $100.00 more that Summit or Jegs. It won't tell you what dealer it is until you give all your information and credit card #. I called Painless, talked with customer service and she said that their computer guy will check it out. For the new restorer like me, I would of thought that was the price had I not looked at the change in the URL. If it wasn't for my brother in law and his paper cataloge,I would of paid $364 rather than 271. Beware, Brian.
Thanks for the tip Brian...I will be buying a harness soon and Painless is one of the sites I looked at recently
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
check ebay too...
Another quality post.
Real Trucks Rattle
Buy from Hotrodwires.com and save even more.
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
how did that one work out Maxx?
Real Trucks Rattle
It will work good It is like the Painless harness
I will need just ten or so of the 21.
And it is real long got lots to work with
Maxx
I'd guess that these trucks, even with electric windows, a/c and electric locks, only need 12 circuits at the most.
I used an 'its a snap' kit with mini blade fuses and it included the signal flashers and headlight relays. It included plenty of wire and the wire was all labeled every 6" with what it was for, plus it was color coded to match GM so I can add a GM column, auto-tranny and ignition switch, or LS-6 and computer, no problem. I picked it up on e-bay for $100. Same as Maxx I had more circuits than I needed or will ever need since I'm using a 261 and t-5.
would have went withez wire had it been an option at the time i bought a 12 circuit painless 10yrs ago and its still not installed.my project was mothballed due to a divorce.and is just now startin up again.they were expensive then $250 . i have since purchased their maxi fuse to install with it that now comes standard on their kits. i'd go with the ez wire ..my .02....dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
