0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Directly below the tail gate on my '41 3/4 ton and right in the center of the rear panel is an old worn out hole. It looks like a guide hole for a crank used to lower the spare tire from under the bed. I have looked at what is left of the original under bed spare tire mount and at the catalog photos and do not see anything that looks like a small winch mechanism or any thing to mount one. So.. I'm wondering what this hole was used for. | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Kip's41,
I don't remember that hole on my truck when I was working on the tail, I will look tonight when I get home and see if I can figure out what it is.
Ed | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kip's41, I am not sure, but it might be where the cobs come out...was this truck ever registered in Iowa? Stuart | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Hey Kip,... Thats were the spare tire bracket secured with a threaded rod with the other end hooked into that hole. You either spun the wing nut off the threaded end and dropped the bracket with the spare or you had the optional spare tire lock that you took off and dropped the spare down. Hope that helps.
1941 AK named "PETEY" my buddy.
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I found some holes right under my tailgate too. I covered them with a Harley Davidson sticker. lol...
delete my account and pictures
The only hole I found under my tailgate was where my reverse light is mounted. I am not sure if this is an aftermarket item or if it came with a reverse light. Other than that I don't have anything else. Hope this helps.
Ed | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I guess its down to determining between Atomarc and Tweak. So unless they grow very small corn in Iowa (the hole was probably ¾” new) I’ll have to go with Tweak’s answer.
Once again thanks for the info  | | |
