| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 6 Junior Member | | Junior Member Joined: Aug 2006 Posts: 6 | I own a 1966 GMC truck and was looking at a 1965 GMC truck for parts. The 65 has a V6 in it that looks to be original but I have never seen a V6 that old and don't know anything about it. Was looking for some info. Thanks | | | | | Joined: Aug 2006 Posts: 3 Junior Member | | Junior Member Joined: Aug 2006 Posts: 3 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What you have will be a 305 cid, they were also made in 351 and 478 as well. These are big, heavy engines, I seem to recall that they weigh in around the 900 pound mark. They are a very torquey engine, not fast, but very powerfull on the low end. There was also a v-8 and v-12 based on the same block, and deisel versions that used different heads and pistons. I've poked around on the site that chevhelper posted, it's very informative.
Bill Burmeister | | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | Hi 66impala, have a look at my truck in the gallery.It was a '66 GMC, now a Chevy. It has the 305v6 in it yet, all rebuilt. I got all my info for the rebuild from 6066 GMC Truck (web site),as chevhelper said, alot of good info. Ted. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A 60 degree V-6, Not 90 degree like most bent engines. Jeep just came out with a similar engine for their Wrangler line. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I thought it was a ninety degree odd fire engine, like the early Buick V6 except alot bigger and heavier. Obviously, I was wrong. Other than the 3800 Buick and 4.3 Chevy engines, all recent V6s have been 60 degrees. | | | | | Joined: Aug 2006 Posts: 6 Junior Member | | Junior Member Joined: Aug 2006 Posts: 6 | Thanks to all. The web site is great. Mark | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | Howdy 66impala, the group link above is the " Discussion Group", the WebSite with tons of info is found here ~~~> the 6066 GMC Guy . Glad you found the info usefull. | | |
