6 members (kades51, frogfarmer, baldeagle, Brian Moore, Hotrod Lincoln, 1 invisible), 28 guests, and 8 robots.
Topics128,020
Posts1,055,345
Members48,419
#21509 11/26/2003 4:06 AM
Junior Member
Junior Member
The other day I pulled my 54 GMC ½ ton truck out of the garage and drove it for a little while then the truck stopped running on me. I tried cranking it for a while with no success. I pulled a plug to check for spark and found I had none. On a whim I changed the condenser but that did not help. Then I took a voltage tester, that kind that has a ground and a light the will light up if voltage is found and checked for voltage at the ignition coil and found none.
Should I have been able to find current at the coil with the ignition switch on? If I should and I’m not, what should I check next?
On the + side of the ignition coil, it has two wires, one runs to the tack and the other to the distributor. On the – side it has one wire running from the firewall that I have not been able to trace to its source. Could I run a wire from the + side of the battery to the – side of the coil to see if I get voltage on the + side of the coil and if I do, try starting it. My thought is I will be bypassing the wiring to and from the switch to determine if that is where the problem is.
Any advice will be appreciated.
#21510 11/26/2003 4:56 AM
...took a voltage tester, that kind that has a ground and a light the will light up if voltage is found and checked for voltage at the ignition coil and found none.
What did connect your tester to?
Is the electrical system original? The polarity you describe sounds like a positive ground system, probably six volt. Is that correct?
The distributor side of the coil is always the ground side.
The wire on the other end should go to the ignition post on the ignition switch.
If your truck has been converted to 12-volts there should be an ignition resistor between the coil and the switch, and the fact you don't mention the resistor mounted on the firewall along with the positive ground lead me to believe this one is stock.
Don't run a wire from the positive side of your battery to the + terminal on the coil. If your truck is positive ground it won't do anything. If its negative ground you might be causing a short and will burn your points or the wire.
Instead, put your test light across the coil, connect one side to the positive and one to the negative, it should not matter which. Then turn on the ignition and try to start the motor. If the light flashes the primary side of the circuit is working.
If it does not flash, or turn on at all, you'll need to trace that wire back through the firewall to the switch and make sure the wire is complete and then that the switch is okay, and that power is getting to the switch. If it flashes your problems are either not electrical, or at least on the secondary side of the circuit.
#21511 11/26/2003 5:00 AM
Yes you can take a jumper wire and jump juice to the (-) terminal on the coil and see if the truck will fire.
Joe
#21512 11/26/2003 6:07 AM
If the points are closed you will not see a light. Sorry it takes 2 people for my way, first and most important make sure test light works, 2nd take test light and put on neg side of coil as eng. is turned over light should flash if no flash remove wire from poss. side of coil and look for light to work
One thing I learned always always make sure test light works
If you have no power to wire stat tracing back
have fun it aint that hard smile
#21513 11/26/2003 6:31 AM
Junior Member
Junior Member
I grounded the alligator clip to the frame and placed the probe on both the positive and negative side of the coil with no indication on current.
No it was converted to 12 volt by one of the previous owners. The Generator was replaced with an alternator also.
Well we know it is not the original system, it is 12 volt. I’m not sure if it is positive ground or not. Was debating this with someone at work today.
Since the + side of the coil is attached to the points, does that indicate a positive ground?
There is an ignition resistor mounted on the coil it is on the negative side of the coil. The coil is a 6-volt coil
This truck has the starter that is engaged by depressing a foot peddle, would I only need to turn on the switch to perform this test or would I need to engage the flywheel?
My hunce is a wire from the switch to the coil has become disconnected. Would this seem correct
#21514 11/26/2003 6:40 AM
Go buy a 12v coil. One should have been installed when the 12v conversion was done. You'll still need to use the ignition resistor to protect the points.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#21515 11/26/2003 4:31 PM
I'd bet dollars to donuts that the coil is wired backwards.
Current flow on a negative ground system:
From key in 'run' posistion thru ballast resistor to + side of coil. Then from - side of coil thru breaker points in distributor to gnd. When the points open, the current thru the coil stops flowing, and the coil throws a spark.
Check for power at both sides of ballast resistor. If no power at ballast resistor, check for a fuse or broken wire between key and wire at ballast resistor.
Positive gnd- positive wire of battery is grounded to frame.
Negative gnd- negative wire of battery is grounded to frame. Vast majority of vehicles are neg ground.
This thing has a regular tach, like a sunpro or autometer or something, right? I've never seen a positive ground one. Does it have a stereo? Both of those accys are usually negative ground.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#21516 11/26/2003 7:18 PM
Its very unlikely that a 12-volt system with an alternator is positive ground. Your coil is wired backwards, and you may have other problems too.
To test the ignition system using the approach I suggested the motor needs to turn, and the foot starter does not have a selinoid to move the starter drive, so it needs to be foot operated.
This is hard to do alone...
I think most the questions you asked me are answered by others above. Keep us posted on your progress.
#21517 11/27/2003 7:13 AM
Junior Member
Junior Member
Lots of good advice from everyone, thanks.
The good news is I was able to get it started tonight. The wire that ran from the ignition switch to the - side of the coil had become disconnected, from where I haven’t figured out yet. Since it was the original wire, I ran my own wire from the ignition switch to the ballast resistor and it cranked right up.
Looks like the coil may have been wired up incorrectly some time ago. I've only had the truck a few months and I have not changed the coil wiring and it looks like it has not been disturbed in sometime. I’m going to try to do some further research before installing the new 12-volt coil.
#21518 11/27/2003 7:48 AM
I don't recall exactly what happens if your coil is wired backward, but it does cause problems. I think it adversely impacts point life. Make sure its wired right when you put the 12-volt coil on it.
#21519 11/28/2003 4:47 AM
IF you wire a coil backassweres the scope picture is upside down and you will get low sparrk output
#21520 12/01/2003 6:06 AM
Junior Member
Junior Member
I remember reading a LONG time ago from chev or a hot rod mag that if coil is wired back'''erds
that the spark does not jump correctly, ie it jumps FROM the ground electrode to the center of the plug and goes back into the coil, thereby greatly reducing the life of the coil.
if coil wired correclty then the JOLT comes from the coil and goes thru the plug center electrode and onto the ground electrode of the plug and then giving the normal life expectancy of the system. a simple test was given use a regullar wooden pencil and put a wire onto anothe plug (grounded of course) and insert the lead into the plug gap (yea hard ain't it)and if the spark starts on the ground side you are wired backard.
