1 members (delky), 127 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
I can't figure out what year is motor is. I am pretty sure it is a Chevy I6 250. The only numbers I can find are
Block- 3789404
GM 5
CON2
D16 3
Head- 2084F57
Then if I can figure out what year I need to know the timing
Thanks for your help, glad you guys are all ways here.
If it is a 250,, the timing is 4* BTDC
From http://www.inliners.org/
3789404 is a 292.
Wonder if the D163 means April 1, 1963......
Craig
If the passenger side motor mount is at the front, it's a 292. If it's at the center, opposite the driver's side, it's a 250.
Fred
52 3600
69 C-10
Thanks for your help, What would the timing for a 292 be?
