| | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21503 08/15/2003 1:43 AM | Joined: May 2002 Posts: 17 Member | | Member Joined: May 2002 Posts: 17 | I can't figure out what year is motor is. I am pretty sure it is a Chevy I6 250. The only numbers I can find are Block- 3789404 GM 5 CON2 D16 3 Head- 2084F57 Then if I can figure out what year I need to know the timing Thanks for your help, glad you guys are all ways here. | | |
#21504 08/15/2003 3:31 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If it is a 250,, the timing is 4* BTDC
#21505 08/15/2003 11:07 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#21506 08/15/2003 2:32 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Wonder if the D163 means April 1, 1963......
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#21507 08/15/2003 6:44 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If the passenger side motor mount is at the front, it's a 292. If it's at the center, opposite the driver's side, it's a 250.
Fred 52 3600 69 C-10
#21508 08/15/2003 6:48 PM | Joined: May 2002 Posts: 17 Member | | Member Joined: May 2002 Posts: 17 | Thanks for your help, What would the timing for a 292 be? | | |
