1 members (TUTS 59),
55
Mod | | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Anybody else have this problem while cruzin down the road.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | True bump steer is a phenomenon caused by improper geometry between the pitman arm, drag link and steering arm.
This is usually a result of an poor attempt to lower the truck, or some other ill conceived steering change.
Poor handling on rough or bumpy roads might be due to loose steering or front end components, bad shocks or extremely wide tires, but I don't think this is actually bump steer.
Stuart | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I had put on a power steering kit onto my straight axle. Which the kit works great but I found that after installing the kit I had bump steer happening. On closer inspection. I had installed the drag link with one ball joint on one end facing up and on the other end facing down. Which cuased the the drag link to be at steep angle from the pitman arm to the steering arm. So what I'm guessing is that when I hit bumps and the suspension goes up and down It changes the angle of the drag link cuasing bump steer
| | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | I had the same problem, and the same setup as you describe with your drag link. Whenever I would hit a bump, the truck would jerk to the left and then back to the right as the suspension compressed/ extended. The steering wheel wouldn't be affected by the bump steer. From what I could understand from all of the techincal info on the internet, The drag link must be paralel to the ground, and a longer drag link has less bump steer than a short drag link. I had the drag link adjusted to be much closer to level and wow! what a difference! It took out at least 80% of the bump steer. It takes a pretty big bump to feel any jerking at all now. Cornering on the highway is better now too; bump steer tries to steer you to the outside of a corner as the truck leans and compresses the suspension on one side. I also installed a front sway bar to help on the cornering. Hope this helps. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | when I hit a good bump in mine you feel it but the truck goes true.........
one of my old mustangs use to have the real bump steer if it was out alined....... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Good post. I am contimplating putting it on my 55-2. I,ve been wondering about this. Any more info will be apreciated. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | I use the original master/slave PS system. One end of slave cylinder is mounted on the driver's end of the solid axle, other end attached to cross steering rod - moves up and down with axle. No bump-steer. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Bump steer can be a problem on solid axle vehicles. The wheels don't articulate inividually as they do on an ifs, so the forces often are tramsferred to the opposite wheel. Power steering does help to aleiviate/mask the problem, especially the slave cylinder type that has a ram directly on the tie rod. Another fix is to add a steering stabilizer. I opted to do that on mine. Moog makes a good one that will fit pre-'59 solid axle trucks. It's a Trail Boss damper, part # SSD12. You might have to do a little fabrication to make it fit perfectly, the mounting hardware is intended for a 4x4 axle. The mounting is similar to the slave cylinder for the factory type power steering.
Bill Burmeister | | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | Longbox, could you post a few pictures of how you installed the stabilizer on your truck? I might want to try one of those some time. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've placed some pix on my webshots page. I still ain't got that picture linking figgerd out yet. The mounting to the axle is a 1/4" stainless plate, the U-bolts that come with the kit do not fit the axle very well. The bolts are grade-8 3/8", 4" length as I recall. The other end is the standard parts that come with the kit. The U-bolts on that end will have to be loosened to adjust toe.
Bill Burmeister | | | | | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | Robin58: Leaf springs are supposed to be flat? I was getting ready to replace mine because the were flat from the enging weight and I figured they were worn out. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have used those steering stabilizers & they work good with power steering but I treid one on my 55-2 without PS & it was horrible. I pulled it off the next day. I will put it back on when I get the power strg. installed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
