5 members (fonz8261, King Kielbasa, Hotrod Lincoln, Otto Skorzeny, 1 invisible), 84 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
#214455 08/25/2006 12:53 AM
Have a slight problem went to get title for a 55 chevy 1/2 ton today and old title was hard to read,,have a new title in hand from court house but I think vin is not correct,,on driver door is plate with info and a ser number #H55J001202,,is this the vin if so I have to get title changed tomarrow as number on new title is not same...help please...doc
#214456 08/25/2006 1:01 AM
Yes, that is the vin. It breaks down to this; 3100 1/2 ton, 1955 first series, built in Janesville WI. The number should be on the frame rail, near the steering box as well.
Bill Burmeister
#214457 08/25/2006 2:53 AM
Ex Hall Monitor
Ex Hall Monitor
Depends on the state. Most states used the engine number (behind the distributer) through 55. The agency that does vehicle inspections (highway patrol in Kansas) can tell you which number you need.
