| | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | Have a slight problem went to get title for a 55 chevy 1/2 ton today and old title was hard to read,,have a new title in hand from court house but I think vin is not correct,,on driver door is plate with info and a ser number #H55J001202,,is this the vin if so I have to get title changed tomarrow as number on new title is not same...help please...doc | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, that is the vin. It breaks down to this; 3100 1/2 ton, 1955 first series, built in Janesville WI. The number should be on the frame rail, near the steering box as well.
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Depends on the state. Most states used the engine number (behind the distributer) through 55. The agency that does vehicle inspections (highway patrol in Kansas) can tell you which number you need.
