2 members (walter74, WICruiser), 77 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
#214370 08/23/2006 10:20 PM
I'm making a remote reservoir for the brake fluid to the master cylinder. I was planning on using the reservoir from the back end of a motorcycle, but the bike salvadge guy wants $60.00. He won't split up the parts.
So, I was at Harbor Freight and I noticed that their touchup gun has a nice aluminum bottle with an air tight cover. Thw whole gun was only $19 so I bought it. That bottle will look sweet hanging from my firewall, and I will check the fluid more often seeing as I don't have to lift the rubber and pull out that god awful plug.
"Happiness equals reality minus expectations" - Tom Magliozzi
#214371 08/23/2006 11:09 PM
Junior Member
Junior Member
I love it when you can find odd parts that are functional and cool.
Be sure that the bottle is air tight. (Darn brake fluid sucks the moisture right out of the air - then big trouble!)
Harbor Freight has great prices for items that I may need to use on a limited basis. Picked up a sawzall for under twenty bucks.
Rick
I feel like I'm diagonally parked in a parallel universe.
#214372 08/25/2006 6:04 AM
GMConviceved I have one of those $20 sawzalls - it works fine, but watch that allen screw on the blades - its a cheapo and wants to strip.
#214373 08/25/2006 9:00 AM
old vw have a resovor use one of those
#214374 06/06/2007 2:46 AM
What type of master cylinder are you using that goes with a remote reservoir?
#214375 06/06/2007 6:37 AM
And how will you plumb it into existing?
