4 members (wilbur53, walter74, 2 invisible),
94
0
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 18 Junior Member | | Junior Member Joined: Nov 2003 Posts: 18 | Hey Guys,
I've got coolant leaking out from around my crankcase cover so I'm trying to replace the gasket. Can someone tell me how to loosen the belt and get the Rotor off the water pump (I don't see any screws or bolts on it).
As always your help is appreciated. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Say what? What "crankcase cover" are you referring to?
To remove the fan belt, loosen the generator or alternator.
What are you referring to as "rotor"? Do you mean the water pump pulley? Depending on what engine you have it either won't come off or it comes off when you remove the fan bolts. | | | | | Joined: Nov 2003 Posts: 18 Junior Member | | Junior Member Joined: Nov 2003 Posts: 18 | Water pump pulley is correct. I was looking at the wrong description on the diagram I have. Thanks for your help. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | psubrewno The pulley will be pressed onto the water pump. Check the weep hole in the bottom of the pump if it is leaking there change the pump. | | |
