1 members (lumbersawyer), 84 guests, and 1 robot.
Topics128,055
Posts1,055,782
Junior Member
Junior Member
Hey Guys,
I've got coolant leaking out from around my crankcase cover so I'm trying to replace the gasket. Can someone tell me how to loosen the belt and get the Rotor off the water pump (I don't see any screws or bolts on it).
As always your help is appreciated.
Say what? What "crankcase cover" are you referring to?
To remove the fan belt, loosen the generator or alternator.
What are you referring to as "rotor"? Do you mean the water pump pulley? Depending on what engine you have it either won't come off or it comes off when you remove the fan bolts.
Junior Member
Junior Member
Water pump pulley is correct. I was looking at the wrong description on the diagram I have. Thanks for your help.
psubrewno
The pulley will be pressed onto the water pump. Check the weep hole in the bottom of the pump if it is leaking there change the pump.
