2 members (chuck2213, qside),
61
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Does anyone have any info on the LED conversion units,(bulbs) for tailights.I would like to get my tailights a little brighter on the 55. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Hi dale937,
Try These threads: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=005407#000000 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002121#000000
1948 AD Pickup
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Tiny,mine are 12 volt.THX | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | THX to all of you for the info | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I believe the filling station sells a kit made just for your lights? Call them and ask to be sure. Grigg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Technostalgia makes a nice kit for the '55-'59 that fits in the stock housing. It has a panel that puts the leds at full coverage of the lens. Also, the bulb repacement type will not work with blue dots, the dot just blocks the light as the lens has to be the same color as the led illunination. Mine have been modified to allow for blue dot operation.
Bill Burmeister | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Bill, what did you do to allow for blue dots to work? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | At the bottom of the housing, there is an area of the LED panel that doesn't have any lamps. I used an led license plate bolt from APC that is mounted in an aluminum bracket that I made. This is mountet to the housing witha small machine screw the goes through the drain hole in the bottom of the lamp housing. I have the hot lead from that wired into the brake/turn signal wiring, so the blue dots only work when the brakes/turn signal is on. I put some pix of it on my Webshots album, I still don't have the picture linking figured out yet.
