0 members (), 62 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#213798 08/16/2006 2:24 PM
Does anyone have any info on the LED conversion units,(bulbs) for tailights.I would like to get my tailights a little brighter on the 55.
#213799 08/16/2006 3:21 PM
Ex Hall Monitor
Ex Hall Monitor
6V - 12V?
#213800 08/16/2006 3:47 PM
Hi dale937,
Try These threads:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=005407#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002121#000000
1948 AD Pickup
#213801 08/16/2006 4:39 PM
I've seen the 12v LED bulbs that fit the stock sockets (1156 single terminal and 1157 double) at truckstops and autoparts stores everywhere for about $10 each. The led bulbs look like this and I think they come in clear, amber and red:
[img]http://cache.speedwaymotors.com/eccStoreFront/product_images/Jess%20Tester/91131020_R.jpg[/img]
http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.433/display_id.3032/qx/Product.htm
If there is at least one incandescent bulb in the turn signal circuit you probably don't need an led flasher.
#213802 08/16/2006 5:46 PM
Tiny,mine are 12 volt.THX
#213803 08/16/2006 5:48 PM
THX to all of you for the info
#213804 08/19/2006 2:37 AM
I believe the filling station sells a kit made just for your lights? Call them and ask to be sure.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#213805 08/19/2006 2:44 AM
Technostalgia makes a nice kit for the '55-'59 that fits in the stock housing. It has a panel that puts the leds at full coverage of the lens. Also, the bulb repacement type will not work with blue dots, the dot just blocks the light as the lens has to be the same color as the led illunination. Mine have been modified to allow for blue dot operation.
Bill Burmeister
#213806 08/19/2006 11:30 AM
Bill, what did you do to allow for blue dots to work?
Larry Bear
55.5 Chevy 3100 Panel
#213807 08/19/2006 7:31 PM
At the bottom of the housing, there is an area of the LED panel that doesn't have any lamps. I used an led license plate bolt from APC that is mounted in an aluminum bracket that I made. This is mountet to the housing witha small machine screw the goes through the drain hole in the bottom of the lamp housing. I have the hot lead from that wired into the brake/turn signal wiring, so the blue dots only work when the brakes/turn signal is on. I put some pix of it on my Webshots album, I still don't have the picture linking figured out yet.
Bill Burmeister
