8 members (DES57, Joe H, baldeagle, gswbbc, TooMany2count, Rusty Heaps, Cheapskate1229, NJC), 190 guests, and 3 robots.
Topics128,040
Posts1,055,474
Members48,424
#213701 08/14/2006 4:25 PM
Greetings Everyone!
I have procured a Suburban gas tank for my '67 1/2 ton Chevy truck. The truck has a short stepside box on it. After some preliminary measurements it looks like I will have to move the rear cross member closer to the rear bumper.
Although I am not too squeamish about the required fabrication and etc. - I would appreciate any suggestions or comments from others who have already been down this path.
Thanks!
#213702 08/18/2006 2:23 PM
Junior Member
Junior Member
tractor,
i'm also working on a gas tank relocation; for my '66 shortbed.
seems the tanks i find available are all to large to fit my bed, what are the dimensions of your tank? where did you get it?
bill graham
#213703 08/18/2006 2:43 PM
most folks just trim off the offending part of the crossbrace,,unless the truck is used for very heavy hauling it should be OK,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#213704 08/19/2006 2:02 AM
on my 64 the filler neck hit the cross member too,so i moved it back.
64 c10
89 rs
62 econoline
50 ford coupe
#213705 08/19/2006 2:24 AM
Something I saw on a loca '65 ford 1/2 ton, the owner got a filler door from a late model car and installed it in the bedside, behind the fender. No filler through the floor. It was a very clean installation and was not noticable from the outside of the bed.
Bill Burmeister
#213706 08/22/2006 7:40 PM
Thanks for all the suggestions!
To answer your question Bill the tank measures
28"x29"x10".
The way I want to situate it, the 28" will go between the frame rails. It is the 29" length that is giving me trouble. There is a small round crossbar that will have to go - that gices me no heartburn at all. After that, the last crossmember on the frame is in the way.
What I am considering is either removing the crossmember completly and fabbing a new one from heavy wall square tubing, or relocating the stock crossmember further back.
I occasionaly pull trailers - anything from a single axle 5x10 utility trailer to a 2 horse
side by side - so strength is potentially an issue.
Thanks Again for all your input! I look forward to further suggestions.
____________________
'67 Chevy C-10 283/350
#213707 08/23/2006 1:45 AM
i missread your post.i had to move one of the bed cross beams.
64 c10
89 rs
62 econoline
50 ford coupe
