| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Greetings Everyone! I have procured a Suburban gas tank for my '67 1/2 ton Chevy truck. The truck has a short stepside box on it. After some preliminary measurements it looks like I will have to move the rear cross member closer to the rear bumper. Although I am not too squeamish about the required fabrication and etc. - I would appreciate any suggestions or comments from others who have already been down this path. Thanks! | | | | | Joined: May 2006 Posts: 35 Junior Member | | Junior Member Joined: May 2006 Posts: 35 | tractor,
i'm also working on a gas tank relocation; for my '66 shortbed.
seems the tanks i find available are all to large to fit my bed, what are the dimensions of your tank? where did you get it?
bill graham
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | most folks just trim off the offending part of the crossbrace,,unless the truck is used for very heavy hauling it should be OK,,brian | | | | | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | on my 64 the filler neck hit the cross member too,so i moved it back.
64 c10 89 rs 62 econoline 50 ford coupe
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something I saw on a loca '65 ford 1/2 ton, the owner got a filler door from a late model car and installed it in the bedside, behind the fender. No filler through the floor. It was a very clean installation and was not noticable from the outside of the bed.
Bill Burmeister | | | | | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Thanks for all the suggestions! To answer your question Bill the tank measures 28"x29"x10". The way I want to situate it, the 28" will go between the frame rails. It is the 29" length that is giving me trouble. There is a small round crossbar that will have to go - that gices me no heartburn at all. After that, the last crossmember on the frame is in the way. What I am considering is either removing the crossmember completly and fabbing a new one from heavy wall square tubing, or relocating the stock crossmember further back. I occasionaly pull trailers - anything from a single axle 5x10 utility trailer to a 2 horse side by side - so strength is potentially an issue. Thanks Again for all your input! I look forward to further suggestions.
____________________
'67 Chevy C-10 283/350 | | | | | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | i missread your post.i had to move one of the bed cross beams.
