5 members (dt235sd, Tim Canfield, Oswald, Hotrod Lincoln, 1 invisible), 95 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#213610 08/12/2006 4:13 AM
Junior Member
Junior Member
New to Stovebolts, just got a 37 chevy p/u and all works good except right front brake grabs,no signs of leakage, jacked it up and it spins easy. Any suggestions will be appreciated. Thanks sj
#213611 08/12/2006 4:16 AM
welcome to the 'bolt!!
is it just grabby? or does it stay locked up?
check the adjustment, clean it up real good with brake cleaner and check that the hub is round.
Another quality post.
Real Trucks Rattle
#213612 08/12/2006 4:26 AM
Junior Member
Junior Member
it just grabs and lets go, but it grabs fast and hard. will take it apart and look at rest of it. thanks sj
#213613 08/12/2006 5:47 AM
Tab Offline
sounds like the shoes have been contaminated. replace them
delete my account and pictures
#213614 08/13/2006 8:50 PM
Junior Member
Junior Member
Took it apart today, in fact a couple of times and cleaned up pads and drum, put it together and adjusted brakes. I drove it and seems to be workig ok now. I kind of think it was more of adjustment problem. Anyways thanks to all. sj
