2 members (2 invisible), 84 guests, and 6 robots.
Topics128,266
Posts1,058,368
Members48,485
#21319 12/18/2001 7:35 PM
Does anyone knows the rod center to center distance on the 235, 261 and GMC 300 L6 engines?
Alexandre Gracia
Alexandre Garcia
#21320 12/19/2001 5:33 AM
You might try asking here http://www.inliners.org/
Joe
#21321 12/19/2001 12:06 PM
Alexandre: Insert bearing connecting rods are as follows:
54 - 55 235 forging/GM part number 3701491
56 - 63 235 forging/GM part number 3836410
54 - 55 261 forging/GM part number 3702448
56 - 63 261 forging/GM part number 3836456
All these rods C to C = 6.8125 inches.
Large end (stock bore) = 2.4372 inches.
GMC 302 forging part numbers 2135419 (early)
and 2341204 (late)
These rods C to C = 7.000 inches.
Large end (stock bore) = 2.4568 inches. :rolleyes: wink smile
Houston? , We have a problem!
#21322 12/19/2001 12:24 PM
Thanks a lot, Chevyman!!
Alexandre Garcia
#21323 12/19/2001 12:39 PM
Chevyman, any info on 292 rods??center to center distance...,
Thanks.
Alexandre Garcia
#21324 12/21/2001 6:44 AM
Alexandre: FYI,info on 292 rods as follows:
forging/GM part number 3789422
forging/GM part number 3789419
These rods C to C = 6.766
Large end (stock bore)= 2.2255 inches
Hope this helps!!! :rolleyes: smile
#21325 12/21/2001 12:04 PM
Helped a lot, Chevyman, Thanks.
Alexandre Garcia
Alexandre Garcia
