2 members (klhansen, Eisenholtz), 44 guests, and 5 robots.
Topics128,023
Posts1,055,373
Members48,420
#213000 08/04/2006 4:57 PM
I have recently disassembled the passenger's door locking mechanism (other questions on this posted under "The Doors") Anyway there is a four digit number stamped on the door handle and I'm wondering if this could be the code for the key, which I don't have. There was no number on the driver's door handle so I'm thinking it could be for the key. Anybody know for sure ???
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#213001 08/05/2006 12:55 AM
You are correct the numbers tell the locksmith how to cut the key. I did the same with a handle I had. any good locksmith should have a book to tell them how to cut it.
1946 1/2 ton
I'm not addicted I just don't know when to stop
#213002 08/05/2006 2:52 AM
Little Horse, Thanks for the tip. I realize the ’46 is different, but if you have had a ’41 stile apart I sure could some advice on how to put one back together. smile
#213003 08/06/2006 10:43 PM
Kip,
I used a 41 handle so I had the option to lock it if wanted to. Send me a message and I will see if I can help, probably not but I'll give it a whirl.
1946 1/2 ton
