2 members (Peggy M, 1 invisible),
94
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I have recently disassembled the passenger's door locking mechanism (other questions on this posted under "The Doors") Anyway there is a four digit number stamped on the door handle and I'm wondering if this could be the code for the key, which I don't have. There was no number on the driver's door handle so I'm thinking it could be for the key. Anybody know for sure ??? | | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | You are correct the numbers tell the locksmith how to cut the key. I did the same with a handle I had. any good locksmith should have a book to tell them how to cut it.
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Little Horse, Thanks for the tip. I realize the ’46 is different, but if you have had a ’41 stile apart I sure could some advice on how to put one back together.  | | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Kip, I used a 41 handle so I had the option to lock it if wanted to. Send me a message and I will see if I can help, probably not but I'll give it a whirl.
