9 members (Bill Hanlon, Otto Skorzeny, cmayna, RoadsScholar, greenie-reddy, ShopRag, Nick in Manitou, Peggy M, 1 invisible),
177
Mod | | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 42 | I have a 1950 3800 1 ton dually. The doors have wing vents. Gping through various manuals/catalogs, I have the impression that 1950 trucks did NOT have wing vents.
My family is original owner (grandfather bought it new), i suppose being a daily driver on the ol ranch the doors could have been replaced.
Thanks Boom!
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
| | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | 51 is supposed to be the first yr. However some titles were done differntly and your 50 could be a 51 in fact. | | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | Boom,
My Information shows that wing vents weren't in the doors until the 51' model year, not sure if it apply to the 1 ton models. Did you check your VIN, could be that your truck was registered as the year it was purchased (some states did that) but was actual a 1951 model year truck. My 52' was actually made in December of 1951 but is registered as a 52'
Gary, Kelly, and Family
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | On the old Chevy trucks many parts have been interchanged.you could have a set of doors off of a 51 on ypour 50.Make sure the VIN no.on the title matches the no. on the ID plate. | | | | | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | An easier way to tell is check for a "crotch cooler". The vent windows were installed in '51 as a replcement for the left (driver side) side vent in front of the door. If you have the vent, you shouldn't have the vent windows. | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Also if the doors have push button outside handles, they are 52 or newer. '51 was the only year with wing windows and turn down handles. | | | | | Joined: Oct 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 42 | Stovebolters Rock!
boltare and Nifty50, great insight.
1) No crotch cooler on my "1950" 2) The door handles are the old turn down style
So i suppose I really have a 1951 1 ton dually 3800 series titled in 1950?
The id plate on the left driver door reads "6HSK2192" however,
We're original owners (grandfather purchased), but the pink slip is a duplicate. Title Shows 1950, 6 cyl, 8800 GVW etc, but checking the VIN number - i is for an old 1980 Ford truck...which we used on the ranch..... :-)
I do have the last license plate issued. CALIF plate issued in 1963. I suppose I can work with CALIF dmv to get title VIN# fixed. Should be a fun dealing with DMV.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The VIN Cruncher says that is a 1950 1-ton...
A door swap or serial number plate swap both seem possible explanations.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
