3 members (TexasA&M48Truck, Peggy M, 1 invisible), 118 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#212636 07/29/2006 12:22 AM
Help! I'm starting to put my 1948 1/2 ton Chev. body on an S-10 chassis. I'd like to know some average heights for the frames.I neglected to measure the 'loaded' frame height of the '48 before removing the body and drive train. I bought the S-10 frame only so it is sitting rather high. I'm trying to determine how high I should mount the body above the frame. I want to lower the truck body by 3 to 4 inches, but don't want it down "in the weeds". Crawl under your trucks and give me some measurements please!
Hello, Welcome to America
press '1' for English
Puess '2' to disconnect until you learn to speak English
Okay, I'll drive downtown and measure someone's S-10, but I don't know of any '47 to '54 around here, sooooo maybe someone with one that is sitting on a flat surface could just stoop over slightly and measure the height of the running board (to the top surface to make it easy ) I can figure the frame height from that. anyone ?
what year S-10?
Another quality post.
Real Trucks Rattle
sometime in the '80, is all I know. The ones I've seen all look alike. On the S-10, I need to know the distance from the frame (bottom) to the ground and the approx. diameter of the tires would be handy.
I am using the long bed, standard cab frame but I don't think that would make a difference..
I think this is what you are looking for.
http://chevy.tocmp.com/chevyresto/4955.htm
Browse around the online manual site when you get a chance. It's a great resource tool.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
That is exactly what I need, thank you BUT I've tried both pair of grasses and still can't read the dimension , looks like 21 1/4 at centerline of the axle . is that right. And is that to the high point above the axle. Thanks again...
From the same Keith Hardy site, here are the 1953 truck dimensions. The numbers look a little clearer.
http://chevy.tocmp.com/chevyresto/53060.htm
tooomany,, is that an ole' indian name? Your shots look good. I had about decided 4 to 5 inches might be about right. I had built my front mounts of 3X2 channel also. It looks like yours are tapered to fit onto an angled part of the frame ? why is that? Can't see in the pics. Is your cab sitting further foreward or is the cab mounts on the firewall? My S-10 is flat back where my mounts need to be. Glad I didn't make tne mounts permanent yet. Thinking the idea of setting it on the frame on blocks might be the better idea. I suppose the cab will be onn and off several times anyway. What year is "Marge"?
My 52 cab is 5 3/4 inches above the frame on my s-10 conversion. At this height the cab floor clears the 700r4 bell housing.
52, could you give me more info? I like the idea of clearing the trans., without cutting the floor. How does the firewall clear the dist? (I assume you have a Chev. V8 )How high are your runningboards above the ground? Got pics?
