3 members (2-Ton, 1955 1 Series, tclederman), 94 guests, and 0 robots.
Topics128,134
Posts1,056,402
Members48,441
i am about to take the 3104 in for painting. i need to replace the bolts on my running boards. they use a somewhat special bolt available, kinda like a carraige bolt w/ a flat head ??? from vendors.
ok
i am using ''elevator bolts'' or another common name is table/ cabinet leveling bolt. it has a big flat head w/ a square shank just below the head. these are designed and used to level tables or cabinets. the square shank is to allow you to turn the bolt up/ down. they come in 1/4''x 20, perfect for our bolts running board. the flat head & square shank is like a carraige bolt but these are (i believe better). to make them fit you will have to belt sand/ grind down two straight sides off the big round head. then you can slid them in to place in the running board slots.
they fit perfectly and a set of 12 cost my $1.00.
hope this helps
Jim & Caroline
I did the same thing. They work great, and the price is right. wink
sounds good... as i'll be cutting off a bunch of them eventually...thanks for the tip
Another quality post.
Real Trucks Rattle
What a timely post ! Ijust removed my running boards yesterday! Wish someone had made a post on how to get them buggers out. Okay, now, where do I get those leveling screws? Keep in mind I live in a very small town.
Hello, Welcome to America
press '1' for English
Puess '2' to disconnect until you learn to speak English
www.mcmastercarr.com has just about any kind of hardware you could want (3577 pages) and they deliver quick. Very quick in most cases I get stuff overnight via fedex. I just did a search for elevator bolts and they carry them.
Good luck on your project!
Jim
Jim
Good luck with your project!
Good to know. I will be needing some that are 1" longer than stock, Now I know where to get them without looking
•1952 Chevrolet 3800 pickup
---All pictures---
