| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21251 03/14/2002 9:50 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | I just read some info I found on line about all 1958 and latter 261's had full remote oil filters , and say's you can not plug the oil lines like on 216 & 235's, of witch I under stand. I just did'nt know they had full flow filter's. Could some one verify this info for me . thanks Don
Don
#21252 03/14/2002 2:28 PM | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | They '58 - '62 blocks (except Canadian) had the fittings present for full flow remote oil filters, but not all actually came with the hoses and filter head. There are some pictures and and explanation at Jim Carter's site. http://www.oldchevytrucks.com/Tips/261_six.htm | | |
#21253 03/14/2002 4:04 PM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | sixwildo, that is where I got my info go to the forgoton 261, That info does not go whith yours the way I read it. I am interested in confirming this becruse I own a 261.
Don
#21254 03/14/2002 5:07 PM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Don
Just a side note. That also means that you can't use filters other than a full-flow--like a bee hive or those for the 235's. | | |
#21255 03/15/2002 5:27 AM | Joined: Jan 2002 Posts: 36 Member | | Member Joined: Jan 2002 Posts: 36 | 56picup , it says to never disconect the oil lines and plug them, as will stop oil flow. The motor I have is a 58 261, that I have never heard run. But have big plans for it, I saw this and knew it needed to be checked out. I saw this at the site listed in sixwildo 's reply.
Don
