1 members (Gray_Ghost), 72 guests, and 0 robots.
Topics128,050
Posts1,055,761
#21251 03/14/2002 9:50 AM
I just read some info I found on line about all 1958 and latter 261's had full remote oil filters , and say's you can not plug the oil lines like on 216 & 235's, of witch I under stand. I just did'nt know they had full flow filter's. Could some one verify this info for me . thanks Don
Don
#21252 03/14/2002 2:28 PM
They '58 - '62 blocks (except Canadian) had the fittings present for full flow remote oil filters, but not all actually came with the hoses and filter head. There are some pictures and and explanation at Jim Carter's site.
http://www.oldchevytrucks.com/Tips/261_six.htm
#21253 03/14/2002 4:04 PM
sixwildo, that is where I got my info go to the forgoton 261, That info does not go whith yours the way I read it. I am interested in confirming this becruse I own a 261.
Don
#21254 03/14/2002 5:07 PM
Don
Just a side note. That also means that you can't use filters other than a full-flow--like a bee hive or those for the 235's.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#21255 03/15/2002 5:27 AM
56picup , it says to never disconect the oil lines and plug them, as will stop oil flow. The motor I have is a 58 261, that I have never heard run. But have big plans for it, I saw this and knew it needed to be checked out. I saw this at the site listed in sixwildo 's reply.
Don
