7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna), 140 guests, and 4 robots.
Topics128,204
Posts1,057,294
Members48,467
I want to put the tallest 15" tire that will fit on stock 15x8 rims. On my 59 panel truck do they make a 31"-33" that is not 12.5 wide? Trying to get a little more freeway speed until I swap the rear end. My truck is the stock height.
Yes, there are narrower tall tires available, usually meant for Jeeps.
Paint & Body Shop moderator
Junior Member
Junior Member
First post here, trying to answer the easy ones first!
As for your tire go for the BFGoodrich All-Terrain KO in a 33x9.5-15 It is the tallest tire you will find that is not 12.5 wide.
The tallest 15" tires are somewhere around 44-48" tall but much wider than 12.5"...
