11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible),
72
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21218 10/06/2003 9:33 PM | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | This is probably a dumb question but I am young so I will ask it anyway. I have seen several places that the 261 is a full flow motor and that the 235 isn't. What does this mean, and what difference does it make for a daily driver? | | |
#21219 10/06/2003 11:23 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | All the oil passes through the oil filter on a 261, on a 235 only like 10% does.
This is why you can't plug the holes on a 261 oil filter.
54 3100 with 235 62 flatbed dump C60 with 261
#21220 10/07/2003 2:16 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is the full-flow oil filtration system only found on the 1958-1962 261 truck engine? Is a bypass-flow oil filtration system found on the 1954-1957 261 truck engines (as it was on the Canadian Pontiac 261 engines)? http://www.oldchevytrucks.com/cgi-bin/htmlos.cgi/0075.2.3940963852016169258 Tim | | |
