2 members (Woodcmiami, baldeagle), 93 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#21218 10/06/2003 9:33 PM
I
I Offline
This is probably a dumb question but I am young so I will ask it anyway. I have seen several places that the 261 is a full flow motor and that the 235 isn't. What does this mean, and what difference does it make for a daily driver?
#21219 10/06/2003 11:23 PM
All the oil passes through the oil filter on a 261, on a 235 only like 10% does.
This is why you can't plug the holes on a 261 oil filter.
54 3100 with 235
62 flatbed dump C60 with 261
#21220 10/07/2003 2:16 AM
Is the full-flow oil filtration system only found on the 1958-1962 261 truck engine? Is a bypass-flow oil filtration system found on the 1954-1957 261 truck engines (as it was on the Canadian Pontiac 261 engines)?
http://www.oldchevytrucks.com/cgi-bin/htmlos.cgi/0075.2.3940963852016169258
Tim
