7 members (Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
146
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21215 06/09/2004 1:49 AM | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | I'm setting up one of Langdon's Holley-Weber carbs and the recommended fuel pressure, I believe, is about 3.5#. What's the factory mechanical pump put out?
#21216 06/09/2004 4:58 PM | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Generally, standard mechanical pumps put out 3 to 5 lbs. Webers are very sensitive to excessive pressure, lots of flooding problems, so you might need an adjustable pressure regulator. Check JEGS, or one of the hotrod mail-order distributors for a pressure regulator. I think Holley makes a good one that's adjustable. Fuel pressure/vacuum gauges are available at just about any parts store, and it's a necessary item in any tuner's tool box. Jerry
#21217 06/09/2004 10:01 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I measured the pressure output of my 261's fuel pump and it is 4 lbs and 2000 rpm.
