8 members (cmayna, 46 Texaco, UtahYork, TUTS 59, jmoore, EchoBravoSierra, Otto Skorzeny, TexasA&M48Truck), 87 guests, and 2 robots.
Topics128,202
Posts1,057,409
Members48,471
I'm setting up one of Langdon's Holley-Weber carbs and the recommended fuel pressure, I believe, is about 3.5#. What's the factory mechanical pump put out?
Generally, standard mechanical pumps put out 3 to 5 lbs. Webers are very sensitive to excessive pressure, lots of flooding problems, so you might need an adjustable pressure regulator. Check JEGS, or one of the hotrod mail-order distributors for a pressure regulator. I think Holley makes a good one that's adjustable. Fuel pressure/vacuum gauges are available at just about any parts store, and it's a necessary item in any tuner's tool box.
I measured the pressure output of my 261's fuel pump and it is 4 lbs and 2000 rpm.
Paint & Body Shop moderator
